Note
Go to the end to download the full example code.
Comparing Model Ouputs#
In this example we show how to compare outputs across iterations or across models. Here we illustrate using two iterations from the same project, but thanks to the use of standardised KPIs, results can be compared across model years or even across cities.
sphinx_gallery_thumbnail_path = ‘../../examples/result_analysis/pax_in_network.png’
from pathlib import Path
from polaris.analyze.kpi_comparator import KpiComparator
from polaris.analyze.result_kpis import ResultKPIs
from polaris.runs.convergence.convergence_iteration import ConvergenceIteration
from polaris.runs.scenario_compression import ScenarioCompression
from polaris.utils.database.migration_manager import MigrationManager
from polaris.utils.database.standard_database import DatabaseType
project_dir = Path("/tmp/Bloomington")
iteration_3 = ConvergenceIteration.from_dir(project_dir / "Bloomington_iteration_3")
iteration_4 = ConvergenceIteration.from_dir(project_dir / "Bloomington_iteration_4")
# This is generally not needed unless you are analysing results from an older model
MigrationManager.upgrade(
ScenarioCompression.maybe_extract(iteration_3.files.demand_db), DatabaseType.Demand, redo_triggers=False
ScenarioCompression.maybe_extract(iteration_4.files.demand_db), DatabaseType.Demand, redo_triggers=False
c = KpiComparator()
c.add_run(ResultKPIs.from_iteration(iteration_3), "A label (it3)")
c.add_run(ResultKPIs.from_iteration(iteration_4), "A diff label [it4]")
c.plot_everything()
Traceback (most recent call last):
File "/home/jamie/git/anl/polarislib/docs/examples/result_analysis/plot_compare_iterations.py", line 25, in <module>
File "/home/jamie/git/anl/polarislib/polaris/runs/convergence/convergence_iteration.py", line 57, in from_dir
iteration.files = PolarisInputs.from_dir(Path(dir), db_name)
File "/home/jamie/git/anl/polarislib/polaris/runs/polaris_inputs.py", line 24, in from_dir
raise FileNotFoundError(f"No such directory {dir}")
FileNotFoundError: No such directory /tmp/Bloomington/Bloomington_iteration_3
Total running time of the script: (0 minutes 0.003 seconds)
